- Jan 16, 2001
- 31,528
- 3
- 76
Hello everyone,
I hope your weekend was a good one. Mine was pretty good. I've been meaning to post this for some time, but I'm finally peeved enough to get around to it. LOL!
My home CD player is a Kenwood 1050CD. Five-disc turntable-style CD changer. It's about five years old. For about the past year, it skips on CDs. It used to be that it would only skip on "scratched or dirty" CDs; wiping the CD would fix the skip, no prob. For about the past 6 months, it skips with most CDs, no matter which "slot" they are in. Again, it's a turntable style CD player, not a cartridge-load type.
I purchased a CD lens cleaning CD. It's a CD, with a little brush mounted underneath. It helped a little at first, now it has no effect.
When it skips, it skips so badly that you have to forward to the next track manually; it will not correct itself. I'm no technician, but to me it seems that the slighest little irregularity in the surface of the CD will screw it up. I have some CDs that are 5-6 years old, with no visual blemishes or defects, yet it skips. I have some newer CDs that won't skip.
To me, it sound like a "laser alignment" problem. The CD player has never been dropped, hit or jarred. It's just been used and used and used some more.
Is it worth taking to a shop to have it fixed? Is it something I can do myself? Thanks for any advice or assistance you can provide. Have a great Sunday evening.
