- Jun 4, 2004
- 17,768
- 16,124
- 146
My desktop recently was infected with a virus I can't seem to remove. It's hijacking occasional Google links and Regedit and the DOS window no longer work. So I've decided to reload windows.
Since I don't want to loose anything critical on the pc I was thinking about reloading windows to a new HD and that way I could pull anything I needed off the old drive before wiping it.
I was thinking about picking up a faster boot drive than the one I currently have - maybe a velociraptor or SSD. Although I'm not sure what kind of improvement I'd see over my old WD 160GB 8mb cache, 7200RPM SATA drive.
PC specs:
P4 3.2E
Asus P4P800 E Deluxe (i865pe) SATA 1 (1.5gbs)
WD 160GB 8mb 7200RPM boot
WD 500GB 16mb 7200RPM storage
2G DDR 400
What would you do?
PC specs:
P4 3.2E
2G DDR 400
What would you do?
