For a quiet 120mm case fan, I think the consensus is gonna be the Panaflo L1A, but you might have problem locating one right now. The Vantec Stealth maybe a good runner up.
For the SK900A, you can use 92mm Panaflo L1A or 80mm of M1A.
Just a reminder that you can find lots of handy information regarding fans and cooling by reading the stickies before you post. One of the sites you'll find in the faq will be here. You can find all sorts of fans and other cooling devices there.
