I got my stuff from Jatwell (thanks, Josh!) and will start assembling my "executive" (read that as "mini"
crack rack over the Christmas holidays. Here are my thoughts and questions:
The rack will be located on a built-in wall unit/desk thing so space and height are a factor (about 24"W X 24"D X 22"H). I'll use 1X2's for the frame and 1/4" pegboard for the shelves with those adjustable shelf brackets. I'll mount the motherboards using those plastic spacers for pegboard so heat can radiate up through the rack).
Originally I had planned on borrowing the monitor, keyboard & mouse from the real computer next to it, but a KVM is probably a more trouble free way to go. I'm looking at this LINKSYS 4 PORT KVM switch. Any comments on it?? Much effect on picture quality? This is my back up PC and it only has a Gateway 15" monitor, so the display quality ain't that great in the first place. Edit: It's $78 at buydotcom.
Is there an elegant solution for power and reset switches? Radio Shack or somebody sell something that will work?
Is Klinux definately the way to go? Floppy drives are cheaper than hard drives, but how much can you buffer on it compared to a small HD with an OS installed just in case the network/cable modem goes down?
Long term, can you run the power supply with the cooling fan disconnected to cut down on noise? I'll be starting with a BP6 so there will already be 2 CPU fans running, it may start sounding like a TWA hanger in the den.
On the PS, I suppose you can't just splice in a second ATX connector (with extensions so it'll reach) from a dead PS and power 2 MB's?
Tks in advance...
Tks in advance...
