need some basic help
drednox
hi
its been ages since the last time i have had a chance to overclock a system way back in teh days of DOS 4.x and Windows 3.0 just barely peaking its head out.
so i forgot everything about how to do it.
now i got a new computer, which should kick some serious butt, but apparently doesnt. best score i have been able to get on the 3d mark 03 is about 5200. i have been told i should be able to easily pass 7k, maybe aproach or even hit 8k.
so i would like to know some detailed info, on how to overclock the CPU and teh video card. also, is tehre anyway to overclock the FSB ? or perhaps mine isnt set to optimal performance at its current setting ?
i dont understand the 133mhz processor speed when my cpu is supposed to be 3.06 GHz or how does that factor in or whats t mean. or how precisely does FSB work, or what should i set it to.
so here are my complete system specs (i should add that hyperthreading is enabled so i get that fnky 1/2 or 2 cpus thing):
CPU Info
CPU 1/2
Intel Pentium® 4 3.1 GHz
Manufacturer Intel
Family Pentium® 4
Internal Clock 3.1 GHz
Internal Clock Maximum 3.1 GHz
External Clock 133.0 MHz
Socket Designation Socket 478
Type Central
Capabilities MMX, CMov, RDTSC, SSE, SSE2
Version Model 2, Stepping 7
Caches
Level 1 8 KB
Level 2 512 KB
CPU 2/2
Manufacturer Intel
Family Pentium® 4
Type Central
Caches
Level 1 8 KB
Level 2 512 KB
DirectX Info
Version 9.0
Long Version 4.09.00.0901
Display Device 1/1
ALL-IN-WONDER 9700 SERIES Driver 6.14.1.6307
Description ALL-IN-WONDER 9700 SERIES
Manufacturer ATI Technologies Inc.
Total Local Video Memory 128 MB
Total Local Texture Memory 128 MB
Total AGP Memory 119 MB
VGA Memory Clock 310.5 MHz
VGA Core Clock 324.0 MHz
PCI
Name ALL-IN-WONDER 9700 SERIES
Vendor ID 0x1002
Device ID 0x4e44
SubSystem ID 0x4f721002
Revision ID 0x00
Capabilities
AGP Texturing, Hardware Transform and Lighting, Positional Lights, Subpixel Accurate Rasterizing, Stencil Buffers, Range Fog, Table Fog, Vertex Fog, W-Fog, Specular Gouraud Shading, Anisotropic Filtering, Bilinear Filtering, Point Sampling, Trilinear Filtering, Additive Texture Blending, Dot3 Texture Blending, Multiplicative Texture Blending, Subtractive Texture Blending, Environmental Bump Mapping, Environmental Bump Mapping With Luminance, Cube Mapping, Factor Alpha Blending, Vertex Alpha Blending, Texture Alpha Blending, Texture Clamping, Texture Mirroring, Texture Wrapping, Guard Band Support, Mipmap LOD Bias Adjustment, Projected Textures, Volume Textures, Point Primitive Support, Full-Screen Anti-Aliasing, DXT Compressed Textures, Two Sided Stencil Test, Mipmapped Volume Textures, Mipmapped Cube Textures, Spherical Mapping, Automatic Mipmap Generation, Hardware Rasterization, Shading, Transform and Lighting, Scissor Test, Legacy Depth Bias
Primary Device SB Audigy Audio [A400]
Sound Device 1/1
Creative Audigy Audio Processor (WDM) Driver 5.12.1.324
Description SB Audigy Audio [A400]
Manufacturer Creative Technology, Ltd.
Max Supported 3D Hardware Sounds 64
EAX Support Supported
PCI
Name Creative Audigy Audio Processor (WDM)
Capabilities
Continuous Rate, Primary Buffer with 16-bit Samples, Primary Buffers with 8-bit Samples, Monophonic Primary Buffers, Stereo Primary Buffers, Hardware-mixed Secondary Buffers with 16-bit Samples, Hardware-mixed Secondary Buffers with 8-bit Samples, Hardware-mixed Monophonic Secondary Buffers, Hardware-mixed Stereo Secondary Buffers
Memory Info
Total Physical Memory 1.00 GB
Free Physical Memory 789 MB
Total Pagefile Memory 2.40 GB
Free Pagefile Memory 2.28 GB
Memory Array 1/1
Max Module Capacity 0 B
Supported Speeds
Supported Types
Supported Voltages
Memory Slot 1/4
Installed Enabled Size 512 MB
Form Factor DIMM
Frequency 266.0 MHz
Slot A0
Manufacturer <unknown>
Type Details
Enabled Size 512 MB
Total Bit Width 64 b
Data Bit Width 0 b
Memory Slot 2/4
Form Factor DIMM
Frequency 266.0 MHz
Slot A1
Type Details
Enabled Size 512 MB
Data Bit Width 0 b
Memory Slot 3/4
Installed Enabled Size 0 B
Frequency 0.0 Hz
Type Details
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Memory Slot 4/4
Frequency 0.0 Hz
Type Details
Enabled Size 0 B
Total Bit Width 0 b
Data Bit Width 0 b
Motherboard Info
Manufacturer Supermicro
Model P4SAA
Version PCB Version
BIOS Vendor Phoenix Technologies, LTD
BIOS Version IntelR - 42302e31
BIOS Release Date 06/12/02
BIOS Properties Plug and Play, Flash, AGP
AGP
Revision 3.0
Rate 4x, 8x (8x enabled)
Available Rate 0x0000000c
Selected Rate 0x00000008
Aperture Size 128 MB
Sideband Addressing supported (enabled)
Fast Write supported (enabled)
Card Slots
Slot 1/8 (PCI)
Order 1
Designation PCI-1
Type PCI
Characteristics
Data Bus Width 32 b
Details Available, Long
IRQ 0
Slot 2/8 (PCI)
3Com EtherLink 10/100 PCI TX NIC (3C905B-TX)
Order 2
Designation PCI-2
Type PCI
Characteristics
Data Bus Width 32 b
Details In Use, Long
Device Class Network Adapter
Manufacturer 3Com
Driver Version 4.31.0.0
Driver Date 8-13-2002
IRQ 18
Slot 3/8 (PCI)
Order 3
Designation PCI-3
Type PCI
Characteristics
Data Bus Width 32 b
IRQ 0
Slot 4/8 (PCI)
Order 4
Designation PCI-4
Type PCI
Characteristics
Data Bus Width 32 b
Device Class Sound, Video or Game Controller
Driver File ctaud2k.sys
Driver Version 5.12.1.324
Driver Date 1-3-2003
IRQ 21
Slot 5/8 (PCI)
Order 5
Designation PCI-5
Type PCI
Characteristics
Data Bus Width 32 b
IRQ 0
Slot 6/8 (PCI)
Order 6
Designation PCI-6
Type PCI
Characteristics
Data Bus Width 32 b
IRQ 0
Slot 7/8 (PCI)
Order 7
Designation PCI-7
Type PCI
Characteristics
Data Bus Width 32 b
IRQ 0
Slot 8/8 (AGP)
Order 0
Designation AGP
Type AGP
Characteristics
Data Bus Width 32 b
Device Class Display Adapter
Driver Version 6.14.1.6307
Driver Date 2-28-2003
IRQ 16
System Devices
Name Intel(R) 82801DB PCI Bridge - 244E
Manufacturer Intel
Name Intel(R) 82801DB LPC Interface Controller - 24C0
Manufacturer Intel
Name Intel(R) 82801DB/DBM SMBus Controller - 24C3
Manufacturer Intel
Name Intel(R) E7000 Series Processor to AGP Controller - 2552
Manufacturer Intel
Name Intel(R) E7205 Chipset Host Controller - 255D
Manufacturer Intel
Monitor Info
Monitor 1/1
Name NEC MultiSync LCD2010X
Manufacturer NEC-Mitsubishi
Max Width 1280 px
Max Height 1024 px
Operating System Info
Operating System Microsoft Windows XP
Version 5.1.2600
Service Pack Service Pack 1
Locale US
Desktop Width 1280 px
Desktop Height 1024 px
Desktop BPP 32 b
Open Processes
Name PID Memory Usage
3DMark03.exe 372 13 MB
alg.exe 1564 4 MB
ati2evxx.exe 1576 2 MB
atiptaxx.exe 1420 3 MB
blackd.exe 1612 7 MB
blackice.exe 1452 5 MB
csrss.exe 516 3 MB
CTDVDDET.exe 1396 2 MB
CTHELPER.EXE 1404 5 MB
CTSysVol.exe 1388 4 MB
explorer.exe 1284 17 MB
Idle 0 20 KB
iexplore.exe 1144 18 MB
lsass.exe 596 2 MB
MsPMSPSv.exe 1744 1 MB
RAM_2K.exe 1436 3 MB
services.exe 584 4 MB
smss.exe 464 356 KB
spoolsv.exe 988 3 MB
svchost.exe 780 3 MB
svchost.exe 832 18 MB
svchost.exe 932 2 MB
svchost.exe 960 3 MB
System 4 216 KB
winlogon.exe 540 4 MB
wmiprvse.exe 664 4 MB
alg.exe 1564 4 MB
csrss.exe 516 3 MB
Idle 0 20 KB
lsass.exe 596 2 MB
smss.exe 464 356 KB
System 4 216 KB
Idle 0 20 KB
System 4 216 KB
smss.exe 464 356 KB
csrss.exe 516 3 MB
lsass.exe 596 2 MB
alg.exe 1564 4 MB
Idle 0 20 KB
System 4 216 KB
smss.exe 464 356 KB
lsass.exe 596 2 MB
csrss.exe 516 3 MB
alg.exe 1564 4 MB
Logical Drives
Letter Label Type Capacity Available
C: Hard Disk 55.91 GB 40.96 GB
D: CD-ROM 0 B 0 B
Hard Disk Info
Hard Disk Drive 1/1
Name QUANTUM FIREBALLP AS60.0
Manufacturer (Standard disk drives)
Capacity 55.91 GB
Model QUANTUM FIREBALLP AS60.0
Interface Type IDE
so what can i do here ? can i raise the cpu speed ? ram speed ? FSB ? overclock video card ? and how ?
in my bios i have some overclocking options that i can use, but i am not sure what to input.
obviously i enabled the L2 cache,
my next otion is a CPU Voltage Regulator. i'm not sure if its a good or bad idea to up the voltage, or if it has to be done if i was to raise the actual CPU clock speed ? if so, by how much ? whats the ratio ? voltage goes in +- 0.025v incriments
Next I have a CPU CLock speed option, rigth now its set to 133, but it can go up to a lot, 165 if i am correct or around tehre. what can i set it up to easily without puting extreme strain on it but gaining a significant performance boost ?
next i have a SPread Spectrum option, not sure if its good to turn it on or off when overclocking, if so by how much ? it goes in 0.25% incriments.
according to the manual that came with the mobo, i am supposed to have a CPU CLock Ratio option as well, but its no where to be found, i do not see it anywhere in my bios.
then there are the RAM settings (CAS, RAS, etc etc), currently i have it set on "by SPD" which is default setting. can i get any extra performance here ? if so what should i input ? system is equipped with regular kingston pc 2700 memory (i think)
and what should i set the AGP aparature size for optimal performance ? is bigger or smaller better ?
thanks
