I have read through the "Attention System Builders" topic and have some idea on my PC components. Any input will be greatly appreciated.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Mainly, gaming
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1000 - $1200
3. What country YOU will be buying YOUR parts from.
I live in Singapore
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I'm no fanboy, I much prefer performance/price
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
mostly minor stuff, like monitor, keyboard/mouse, HD
6. IF YOU have searched and/or read similar threads.
Yes, I follow the "Attention System Builders" topic
7. IF YOU plan on overclocking or run the system at default speeds.
Don't know yet, I do not plan on OC right of the bat but will consider it in the future
8. WHEN do you plan to build it?
ASAP
I'm thinking of getting:
CPU : Q9550
GPU: Radeon HD 4870 1GB
Casing: Coolermaster Cosmos
Power Supply: Antec earthwatts EA500 500W ATX12V v2.0 Power Supply 100
CPU Fan: ARCTIC COOLING Freezer 7 Pro 92mm
Please help me pick out the Motherboard, and RAM
I want my PC to be future proof, meaning I want to be able to upgrade to DDR3 in the future and Crossfiring my Radeon
Thank you in advance
Cheers..
Mainly, gaming
$1000 - $1200
I live in Singapore
ASAP
CPU : Q9550
Cheers..
