Need some advice
bigstrickler
185
Whats the best deal for memory. I need pc3200, looking for 2gigs. Around $200 or less is what I'm looking for.
hurtstotalktoyou
2,055
9
hurtstotalktoyou
2,055
9
Probably, yes. Corsair is, if I'm not mistaken, the de facto standard in whitebox PC memory. Patriot and OCZ are both respectable, of course, but I doubt they're any more reliable. Also, the Patriot is 3-4-4-8, not quite as fast as the 3-3-3-8 Corsair.
Also, apparently you can get the Corsair $0.90 cheaper and a few days faster at NewEgg than at ZZF. I missed that before.
bigstrickler
185
So the corsair is better than the OCZ also? BTW what is 3-3-3...etc what does that mean and what numbers are the best or really good
hurtstotalktoyou
2,055
9
3-3-3-8 are latency values for the memory. The lower the better. Also, a lower voltage may allow you to overclock it to even higher speeds and/or lower latencies. Generally speaking, however, neither make very much difference. Heck, even DDR333 (PC2700) memory isn't much slower than DDR400 (PC3200).
OCZ used to be a nice brand, but lately I've been hearing about their RAM having some issues with the latest generation of motherboards. I'm not sure if there's any truth to those rumors, but it's always good to play it safe.
In this case I'd go for the Corsair. But keep in mind that's just my opinion. This isn't an exact science.
bigstrickler
185
What if you dont overclock your ram...are these numbers still significant performance wise? Also why is the last number so high...8 compared to 3's
hurtstotalktoyou
2,055
9
They're not significant whether you overclock or not. The performance difference between the highest and lowest DDR400 latencies is probably less than 2%.
I'm not sure about the technical background of the numbers. What's important is their impact on real-world performance, which is minimal.
Usually the only time I look at latencies is when two kits are the same price. It's a sort of tiebreaker statistic.
bigstrickler
185
ah I think i'm going to resist my temptation to buy 2 gigs when I already Have one and everything is running ok now...sigh its so hard I tell you so hard...lol
Blain
All that posting for nothing? :roll:
Note to self: Remember username "bigstrickler"
