- Nov 14, 2002
- 92
- 0
- 0
Was wondering...was looking through Catalyst Control Center (have a Dell 435MT with a Radeon HD4850 512MB) and noticed the ATI Overdrive settings. I've always wondered if my fan on the video card wasn't running enough...when I'm at 0% GPU load (using GPU-Z) my GPU temp tends to be around 56-57 C and my shader temp tends to be about 60 C.
Was playing GTA 4 PC last night and noticed that the max shader temp while I was playing had been 92 C, but the fan had only ramped up to 42% at most.
I tried an experiment--enabled ATI Overdrive, set manual fan speed to 60%, and played GTA 4 for an hour. Noticed that the max shader temp had only been 83 C, a significant decrease.
I also tried running the fan at 30 percent and noticed that my idle temps were down--GPU and shader to 52-53 C under 0% GPU load.
So, the following questions:
(1) Is there any harm to my video card or fan by running the fan at 60 or 70 percent while I'm 3D gaming?
(2) Is there any harm to running the fan at 30 percent constantly?
Thanks for your help.
