Need some advice on my next upgrade.
Howard
47,982
11
Right now, I've got an Athlon XP 1800+, 512MB PC2100 SDRAM (2 DIMMs), an ECS K7S5A and a GF2 GTS.
What do you suggest I replace those items with? The motherboard should have at least onboard LAN, and I would prefer to stay with AMD.
TIA
DaveSimmons
40,730
670
What do you want the speed for, gaming? Any budget constraints on CPU or video? What kind of hard drive setup (1, 2, RAID-1)?
Howard
47,982
11
I didn't list the hard drive because I don't feel the need to upgrade it.
Budget? As low a price as possible, I guess. I don't want to spend any more than I need to to play new-ish games like CS:S.
bob4432
11,727
46
get a cheap skt939 nf4 board w/pci-e, a64 2800-3000 and 6600gt pci-e with 1GB pc3200. this should be fine for cs:s
DaveSimmons
40,730
670
Is 1024x768 gaming OK? Then a nv 6600GT for the video. For 1280x1024 an ATI X800XL or nv 6800 GT. For 1600x1200 maybe a 6800 Ultra.
You probably want an nforce4 socket 939 motherboard with PCI-E and an A64 3200+.
You don't need a SLI-capable motherboard.
Which mobo? Somone else will need to pick that, I haven't been following specific models since I plan to keep my P4 3.2C and i875 motherboard for another year or so.
Howard
47,982
11
1024x768 is fine, although 1152x768 or 1280x960 would be preferred.
Can you tell me why I need PCI-E? And like I said, I don't want to spend too much. I don't see myself playing new games at all (besides CS:S).
