- Mar 11, 2008
- 12
- 0
- 61
System Specifications:
I. Processor/CPU: Intel Core i7-2600K
II. Current Graphics Card: MSI N470GTX-M2D12 GeForce GTX 470
III. Display Resolution: Currently 1680x1050 but moving to 2560x1440
IV. Power Supply Unit Specification (Brand, Wattage, Ampage, Age): 750W PC Power and Cooling S75CF
V. Case Specifications(N/A, Model, Length, Low Profile, Cooling, HTPC, Water, Silent): Thermaltake Armor+
Hey everyone,
I was looking for some advice on upgrading my graphics card. I currently play games at the 1680x1050 resolution and my GTX 470 handles that pretty well but I will be buying a 27" monitor with the 2560x1440 resolution and was basically wondering if you think I should wait for the next line of cards to come out or if it's worth upgrading now? I was looking at getting this GTX 670 4GB since it's only $380 after rebate and from everything I've read, will handle the new resolution pretty well. Money isn't really all that important but I usually go with best bang for my buck. So I usually end up with the middle card in the Nvidia series. So how long do you think until the GTX 770 (guessing it will be the 700 series) comes out? I am willing to wait if it won't be that long since I can continue to use my current setup with no problems. I'm just looking forward to really upping my resolution to 2560x1440. Thanks for any help or suggestions!
Hey everyone,
