Need some additional 4 pin power connectors for my fans
Pandemic
8
Hi, I dont seem to have enough 4 pin connectors from my power supply (750 w ocz gamerstream) for all of my fans etc. I seem to be about 3 short. Whats the option to add more 4 pins? Would I have to buy another power unit or can I get around that somehow?
cheers
Pandemic
8
ah think i have to connect some of the fans together then power them. that should solve the problem
bruceb
8,874
111
Almost any computer store will have the Y cables listed above .. try a Compusa
or Best Buy ... you can also make them yourself if you have the correct type of
Molex Crimp Tool .. the Molex Shells and Pins can be had at most Electronics Parts
places
corkyg
Elite Member | Peripherals
27,370
240
Or, you can get them from Newegg - this is the sort of thing you are looking for.
Splitter
