Originally posted by: Prodigy3682
I'm on a intel P4 2.66GHz, not overclocked and temperatures on MBM are 95 degrees F for system and 138 degrees F for CPU. My fan RPM is 2428 and I'm using retail heatsink and fan. My case doesn't have exhaust in the back but 80mm on side blowing cold air in, 2 80mm in the front blowing cold air in, and twin turbo 2X80mm fan exhaust system located in my 5.25bay. I used regular thermal compound with 10% silver and put some on my CPU and scraped it off lightly with a razor blade to produce a thin layer. WOULD YOU RECOMMEND ME TO GET A NEW FAN AND HEATSINK? What are some suggestions...for now before I get water cooling in 2 or 3 months????
Well, I was about to post to ask you what your system temp was. 95F = 35C, which isn't too bad. Room temp is generally in the low-mid 20s, so 35 is reasonable. My system temp hovers in the 32-35C range, and I have no problems. Someone correct me if I'm wrong here, but the general rule I've heard is that you should aim for a system temp about 10C higher than your room temp. It looks like you're in good shape there.
Of course, my CPU temp hovers in the 43-45C range, while yours is... about 59C? Yes, that's a pretty big difference. Keep in mind that I also have an Abit motherboard (KG7-RAID), so you'd think that if the motherboard is reporting a high temp for you, it would be doing the same for me. Given that your airflow seems fine (both qualitatively, with all your fans, and quantitatively, judging by the difference between your system temp and room temp), I agree with NightTrain: there's a problem with your HSF. I'd guess that it's not seated right on the CPU. On the other hand, I didn't use the retail HSF with my XP, so I don't know what a normal temp would be.
FYI, if you decide to get a new HSF, here's the one I have:
Arkua 7258. It's silent to my ears, and it does a very good job.
