Need soem help
Freaky
39
i was trying to make a copy of my dreamcast games CD (Crazy Taxi and Ramen2) to make sure i dont loose the game if the original cd gets damaged. i burned it in a cd, the size of the contents in both the cd's are same, but the console dosent recognises the burned cd, is there any thing in particular i have to do while burning the cd. help me guys. Thank you guys in advance
Freaky
39
No i just used adaptive easy cd creator (Copier delux), should i use a specific program to copy. Thank you
