That Inwin A500 case used to be mine. Unlike a stock A500, it is capable of some very good airflow thanks to the blowholes. You can get a quiet 80mm fan for the hole right above the CPUs and that would probably do the job, but if you want to go overboard, put a 130CFM YSTech fan on the 120mm side blowhole position. The power supply is equipped with a super-quiet PC Power&Cooling "Silencer" 80mm fan instead of the stock fan, too. 🙂 Good luck ss59!
Quiet fans: get a L1A Panaflo from Teamawe.com.
Powerful fans: get a high-output fan or two from Plycon
