Need skilled persons to go over my build
Fat Tony
Ok lads ive come into some cash and have decided to get a new build ....... this is the first build ive done on my own and i thought i would ask you lot for a little help, suggestion and pointers. I mainly want a gaming machine and try not to pay attension to the prices as such as i only got them off one site and if i buy this setup i will shop around a little first.
CP-128-IN Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail (CP-128-IN)
£214.95
MB-152-AS Asus P5W DH Deluxe WiFi (Socket 775) PCI-Express DDR2 Motherboard (MB-152-AS)
£137.95
GX-045-CO ATI Radeon X1900 ***Crossfire Edition*** 512MB GDDR3 TV-Out/Dual DVI (PCI-Express) - Retail (GX-045-CO)
£214.95
GX-047-CO Connect3D ATI Radeon X1900 XT 512MB GDDR3 AVIVO TV-Out/Dual DVI (PCI-Express) - Retail (3056) (GX-047-CO)
£179.95
MY-097-CS Corsair 2GB DDR2 Value Select PC5300 Dual Channel Kit (2x1GB) (VS2GBKIT667D2) (MY-097-CS)
£114.95
CD-020-AS Asus DRW-1608P3S 16x16 DVD±RW Dual Layer ReWriter (Black) - Retail (CD-020-AS)
£24.50
CA-008-TT Thermaltake VA7000BWA Shark Aluminium Full Tower - Black (CA-008-TT)
£69.95
PSO-600XST OCZ 600Watt GameXstream PSU, SLI Ready, Active PFC
£91.59
HD-046-WD Western Digital Caviar SE16 250GB 2500KS SATA-II 16MB Cache - OEM (HD-046-WD)
£46.55
£46.55
SC-043-CL Creative Sound Blaster X-Fi Xtreme Music - OEM (SC-043-CL)
£56.99
CD-001-AP OcUK Value Floppy Drive - Silver (CD-001-AP)
£7.00
Total £1,392.91
Thanks for your time
soydios
2,708
*EDIT*: D'oh, I forgot, you're in the UK. Try to find the products listed below at UK retailers (I have no clue who operates in the UK).
Looks fine. I would recommend faster memory, though. Check out one of these three (all prices are before mail-in rebates):
$220 - OCZ Platinum XTC 2GB(2x1GB) DDR2-800 (4-5-4-15): http://www.newegg.com/Product/Product.asp?Item=N82E16820227089 <-- I have this one
$230 - OCZ Platinum XTC Rev.2 2GB(2x1GB) DDR2-800 (4-4-4-15): http://www.newegg.com/Product/Product.asp?Item=N82E16820227139
$200 - G.Skill 2GB(2x1GB) DDR2-800 (4-4-4-12): http://www.newegg.com/Product/Product.asp?Item=N82E16820231087
Have you considered any third-part heatsinks? They're often quieter and better than the stock heatsinks.
For CPU:
$50 - Zalman CNPS9500-LED: http://www.newegg.com/Product/Product.asp?Item=N82E16835118223 <-- I have this one
$50 - Tuniq Tower 120: http://www.xoxide.com/tuniq-t-120-hsf.html <-- also popular
For Graphics Card:
$35 - Zalman VF900-Cu: http://www.newegg.com/Product/Product.asp?Item=N82E16835118001 <-- I have the LED version of this
Hidden Hippo
183
Very nice setup. Looks like it should all go pretty well. However, I don't believe that there is much point in crossfire unless you are playing at very high resolutions. Also, with that rig, the RAM really isn't that great. I would say to ditch one of the graphics cards (possibly get the HIS IceQ 3 X1900XT - very nice card) and then get some nice overclockable RAM with some very good timings. The other thing I would say is that the Shark case hasn't had particularly good reviews and in my personal opinion the Armour is nicer, but that is up to you.
stu1811
405
I have the shark case. Its eh. The lights are nice on the front and it has good construction, but I think the grill on the side of the case slows the flow of air from to the rear
