Need shelves for my components
Electric Amish
23,578
Now that I have my 50" plasma mounted on the wall, I need some fancy shelves to put my components on (HD DVR/Sat. Receiver, DVD Player, Onkyo Receiver, Xbox).
I would prefer something that I could mount on the wall either to the side or under the TV. I also need something to hide all the wire as well.
Does anyone here have any suggestions?
Thanks.
kenrippy
1,763
worst buy has something like this or this if you wanted to get a look in person.
i installed the latter on a side wall under our arm mount 47" LCD in corner of the lvng room. it worked ok, but not exactly what i needed. the wire management was a PITA also.
i ended up just building something from home depot parts for about $40
2x 14x48" extra shelf material in the closet orginization section
2x 2' shelf wall brackets
4x 9" shelf supports
it fits nicely in the corner and does just what i need. the wire management is not great either, everything just runs down the back, zip tied together. not bad.
