wirelessenabled
I installed the new 3.03.2.2a version of SetiQ following the instructions by shutting down my Q, expanding the .exe file over the top of the old files and then restarting the Q.
When I try to login it asks for a username and a password. The old version only asked for a password. When I leave the username blank and enter my password I get the "Access Denied" message.
I prowled around the .ini & .cfg files and saw a username in one of them of http .
If I login with a username of http and my (correct) password I get the message
"You are logged in as 'Http User'
The question is how do I change the settings? Their is no edit settings on the settings page. Where has it moved to or am I not really logged in?
Also how do I change, find or enter a user name besides http ?
TIA
TIA
