- Dec 26, 2004
- 11,905
- 148
- 101
I posted a topic earlier today but no responses. I have a few new things to add to see if it will help anyone reply to my problem. I'm just getting the hang of and getting into alot about computers but I don't know as much as most of you do on here so I need some help... here's my problem: I've had my new setup for about a 2 months now and everything has run very smooth until just today. I got home today and booted up, everything went fine. I got to my desktop and started up a few programs and left to go get something to eat (20-25 mins max). I came back and the screen was still there and my mouse could move around but when I went to click on something it wouldn't highlight or recognize me clicking there, like it wasn't responding. So I rebooted and it went through the POST fine but before it got to the windows loading screen, I got an error that said
Windows could not start because the following file is missing or corrupt:
\Windows\System32\Config\System
You can attempt to repair this file by starting windows setup using the original setup CD-rom select 'r' at the first screen to start repair.
Any key you pressed at that error screen made it reboot. So I popped in the Windows cd and booted off the CD drive and got to the windows setup screen (Install,Repair,Quit). When I pressed 'r' to repair it says that it does not recognize any hard disks and to check to see if they're connected. It says the same exact thing when I try to isntall windows over again. But when I go through the POST it recognizes my RAID setup, but the windows install doesn't.
My specs:
A8N SLI Deluxe
BFG 6800GT (1 for now)
2x80GB Hitachi SATA HD's (RAID 0)
OCZ Modstream 520W
2x512 Mushkin Ram
Audigy 2 ZS
I was told one or both of my Hard drives might be bad but at POST they are both recognized? Looking for some help, any little thing will do. Thanks a bunch.
My specs:
A8N SLI Deluxe
OCZ Modstream 520W
2x512 Mushkin Ram
Audigy 2 ZS
