Ok i bought This scanner which has "Built-in SCSI-II, two 50-pin connectors"
I need to find a controller card and cable that will work with this, a search on ebay wasnt too helpful, i just found older hardware.
http://www.cablesnmor.com/scsi-2-card.html
http://www.cablesnmor.com/scsi-fast-cables.html
Those are links to a controller and cable i found, but it'd be $75+shipping and I KNOW it can be found for cheaper. So basically, my question is where can i get a good card and cable for cheap, and is SCSI II the right kind? Thanks.
