I installed it and got locked out. The username and password changed to something unknown. Didn't want to do a 30-30-30 reset or deal with it anymore. It's in the box to get shipped back tomorrow.
Try this username:admin
Password:admin
Password:admin
It was the first thing that I tried besides my own password and username. On another note, is there any reason I should upgrade my WRT54GS2? It was made in 2007.
If you installed shibby tomato admin:admin should be the default user name and password. What do you mean upgrade your WRT54GS2? You mean upgrade the firmware?
I mean buying a new router. Otherwise, I'll just keep using it. Going to return the Asus.
BeeBoop, this may help.
I got locked out once and this post from shibby in the comments section saved my butt.
http://www.myopenrouter.com/forum/t...DD-WRT-to-Tomato-cannot-login-user-pw-denied/
If you do return the Asus and you want to try the R7000, Staples has a deal through 4/4/15.
I wanted the same one Tuspac is using because they have an easy way to put in the user name and password. Does tomato allow this?
Edit:
User name and password for a VPN.
Edit 2:
Okay, I see in his previous post where he linked to what he is using. There's about 15 files. I'll just pick the latest one.
Thanks! That worked. Do I have to upload that second file you gave me? I'll have to finish this later tonight! ahhhh
Why doesn't the wireless work? I have the password set to WPA2 and it didn't work. I set it to WPA, it still doesnt work. I'm stuck at "Obtaining IP address". I only installed the chk file.
