B boed Senior member Nov 19, 2009 538 12 81 Nov 10, 2018 #1 Hello, I have a stand and a Dell U3011 monitor. I don't have any of the mounting bolts. Anyone know the specs or where I might get some?
B boed Senior member Nov 19, 2009 538 12 81 Nov 11, 2018 #2 I got some M4 12MM .7mm pitch bolts and they work in case anyone comes across this issue.
mxnerd Diamond Member Jul 6, 2007 6,799 1,103 126 Nov 11, 2018 #3 Searched for you. https://www.anandtech.com/show/4070/dell-u3011-review-dells-new-30-inch-flagship The weird part about the U3011's mounting arm is that it connects to the 100 mm VESA mount on the backside of the display with 4 T-10 Torx screws == Even T-10 Torx screw seems having many different shapes & sizes. Click on images for Google search results https://www.google.com/search?q=T-10+Torx+screw == VESA screws https://www.ergotron.com/en-us/support/vesa-standard So for your Dell 100mm VESA, the screws should be M4 x 10 mm Last edited: Nov 11, 2018
