- Jan 6, 2005
- 14,698
- 1,909
- 126
Back in 1997, I started getting into photography, and purchased a Nikon SLR (dont recall the model number) and two lenses to get started:
Nikon ED AF Nikkor 70-300mm 1:4-5.6 D
Nikon AF Nikkor 24-120mm 1:3.5-5.6 D wide angle
About two years ago, I switched to digital, and purchased the D70. The kit came with:
Nikon AF-S Nikkor 18-70mm 1:3.5-4.5G ED
The new lense is somewhat redundant to my wide angle, but I actually find uses for both. One thing I have noticed is that the autofocus sometimes struggles on my older lenses, so I typically switch to manual focus on the older lenses, and autofocus for the lense that came with the D70. Otherwise, I am very happy with my older lenses, even though they are over a decade in use.
I do find conditions where my lense kit doesn't fit the bill, usually for close-up shots.
I don't know enough about lenses to determine as to whether or not my current setup covers most typical conditions. I just know that with trial and error, I can usually get the shots I want with the lenses I have, with the exception of close-up shots.
Questions for the forum:
1. Would you recommend getting a Micro lense to complete my kit, and if so, which one?
2. Given the three lenses I already have, would you recommend upgrading and/or supplementing my existing kit with another lense, and if so, which one?
