I'm looking for a moderately price case that will take an extended atx mobo (12" x 11.5"). Prefer mid tower over full tower. I'm not interested in any of the "cube" type cases. Any recommendations? Thanks.
Try this case... If eATX isn't critical, I recommend this case. Or, if you score some cash, this case. If you check with other vendors, just make sure the case is the same one...
