Need recommendation on sound card
Falcon011
25
I play a lot of games and listen to Mp3's.
Which card is better:
Sound Blaster Value or Sound Blaster Gamer?
I dont really understand the difference between them. Gamer comes with Dolby 5.1 and some games, but is it the same card as the value?
Or should I get something entirely different?
Thanks,
Falcon
Noriaki
13,640
The X-Gamer is the same card as the 2nd edition Value, the gamer just has a different software bundle.
The X-Gamer 5.1 is the same as those two but adds 6 channel analog output capabilities...
But I think you should consider a TB Santa Cruz.
See this thread and look for a long post by user Techno.
Mem
21,476
13
For gaming just buy the SBlive Value 1024 OEM it does a great job,btw there is not much difference between the other models & in gaming no difference.
