Need recommendation on network connection utility?
The Wildcard
Hi there,
Was wondering if anybody had any recommendations for a utility for Windows 7 x64 that shows the following:
1) All network connections
2) Send and Receive kb/s data for EACH connection
Other than Resource Monitor, any recs?
Thanks
Doesn't have any use in Windows 7, unfortunately. It says so right at the TCP Optimizer page. It's also not what the OP is looking for.
sorry,, my friend
But you can also do this. Go to www.download.com and download Tune Up Utilities
and that has optimzer in there and you can tweak it. Amazing program been using it for years and years. You choose your mbit and it tweaks the net settings,, and this works for W7 also. thx
Armen
