- Jan 23, 2007
- 1,417
- 392
- 136
I bought an X96 Air box for about $60 maybe 4 months ago. While it works fine with Amazon video, Hulu, Netflix and Paramount Plus, it does not work ok with Disney plus or |HB|O max. I liked the specs of the box, Amlogic S905X3 quad core processor, Mali G31MP2 Gpu, 32 gigs of onboard storage, and 4GB of system RAM.
With Disney Plus, I had to sideload the app, because it wasn't showing up on the |Play store. I got no audio until I downloaded shows as a file. With HBO Max, I get no audio, period. Hulu worked fine after sideloading it and trying different versions. I've spent way, WAY too much time troubleshooting audio issues, and I'm done. I just need something that is confirmed to work with no issues out of the box with all of the major streaming services. (and also confirmed to let you install from the Google Play store)
I have a dumb ~6 year old 1080p TV, with car stereo speakers hooked up to it, and I'm using HDMI to send video & audio to the tv set from the Android box. I have a Logitech wireless mouse that I use with the box from my couch.
Can anyone recommend a rock solid Android set top box that will work fine with these?
Thanks so very much!
