need recommendation for security cameras/system
JWade
i need to get cameras/whole system for a security system. 5 to 8 cameras, needs to cover two buildings. needs good enough resolution/picture to be able to identify anyone who steals stuff.
cost? dont really have a budget limit, because i dont know what to look at/my choices
Here is a link to a webpage that discusses the issues of detection vs recognition vs identity related to security cameras at various distances. I'm not recommending them or their cameras (don't know anything about them), but the website will give you some things to think about. It doesn't mention it, but those issues are also different at night or in low light versus in the day.
Are you going to build and install the system yourself, or are you going to go to a security company?
A really good source of information about security cameras is the IP Cam Talk forums here. They have camera reviews, and reliable sources for high quality cameras from Hikvision and Dahua (two of the better camera OEMs).
i personally have hikvision 6-mp or 8mp poe cameras and a hikvision dvr, it works and looks great, i also pair it with solar flood lights in areas that will light before the person gets to the camera, but this system looks OK
Use the coupon affsus8ch4kkit100w35 to get an additional $100 off
it uses frame to frame comparison for motion detection, i think PIR is better but they all seem to give soooo many false alarms that notifications seem crazy.
Hello, I'm Samuel, and my dad is running a bike garage for the last five years. Now we are planning to make the employee's attendance digitally through an access control system. We need an expert group to accomplish this work. What is your opinion?
Hello Donald.
I recommend this for taking digital attendance: https://www.newegg.com/hp-prodesk-600-g2-business-desktops-workstations/p/N82E16883997341
However, you might want to also consider using biometrics to take attendance as well, as bikers are known for getting around computer security and firewalls.
Hope this helps.
