Guys I have been out of the system building space for years. The last system I built used state of the art Athlon XP 2000 (ok back then it was sweet). My brother is building a workstation out in Cali. strictly for use as a modeling/animation workstation. I believe one of his main apps is Maya. He is taking a certificate program so he can break into animation or gaming industry and needs something that cuts down rendering time. His current dual xeon (~ 2 x 2.7-3.0 Ghz) Alienware system (2-3yrs old) isn't cutting it any more.
With all the chipsets that are out there I am real confused to what some of best dual CPU mb's that can support an 2 x Intel quad core xeon cpus are. I favor Asus and Abit MB's since they are reliable and since I dont care to overclock much. My bro wants to get the Supermicro X7DAL-E.
He doesn't need the absolute bleeding edge combo but something comparable would be nice. The budget is about $1,600 - $2,000 for a MB, 2 CPU's, quite/cool case, power supply, heat sinks/fans, sound card.
He already has the video card , vista 64, and ram (hopefully the CORSAIR DOMINATOR DDR2 PC2 8500 is good) Any links and comments would be helpful to build the best system for our budget.
First time poster long time reader
