Need recommendation for a heatsink fan for Athlon XP 1900+
zuffy
684
OK, I got my system all setup and running, except one big problem. The heatsink fan I got for my system is overkill and TOO LOUD. It sounds like a jet turbo engine, and just as loud or louder than the Compaq Proliant servers I support at work. It's the OCZ Goliath 80mm 6000rpm heatsink. Can someone recommend a much quieter heatsink / fan or just an 80mm fan I can replace to have adequate cooling. I do not plan to overclock.
swifty3
Banned
Nov 24, 2001
392
What is the CFM count for your fan? and what is the decibal level? look here, and also look in the cases and cooling cat.
Here
zuffy
684
IT's a 50CFM 80mm fan. I don't know the db, but it's friggin LOUD. With this fan, I was getting 35c idle and about 41c under load. I can't take it anymore so I replaced the fan with a lower rpm 80mm and now it's at a reasonable 48c idle. I stress it a little and it went to 50c.
