Need Recomendation on a Hard Drive.
Based on the system Below what would you guys recomend as a hard drive the brand that is that is in the range of 80gigs to 120gigs , that is which brand and which model....And where should i purchase it from pricewatch or newegg. Or should i just go to my local Best Buy or Compusa......Any input would be greatly appreciated. I'm basically Going to have two hard drives at my disposable even though i am going to use my removable hard drive unit. I would love to use the hard drive i have now with another hard drive in raid but i'm not really that great on knowing where to start in order to get a raid working on my computer, i think i'm going to stick with the removable hard drive unit i have the rh10 by lian li.
Input wanted on what drive i should buy, criteria ATA100.
System
CPU: AMD Athlon XP 1470MHz @ 1477MHz
Motherboard: ASUS A7V266-E
Memory: 512 MB of MICRON PC2100 DDR
Video Card: Visiontek Xtasy 128 MB (GeForce 4 Ti4600)
Hard Drive: MAXTOR 30.0 GB @ 5400 RPMS
Monitor: IBM 19inch G94 MONITOR
CDROM Manufacturer & Model: ACER 56X
CDR/CDRW Manufacturer & Model: ACER 24*10*40
Sound Card: SOUNDBLASTER LIVE 5.1
Internet Provider: COMCAST
Internet Connection Type: Cable
Internet Connection Speed: CABLE MODEM
Operating System: WIN XP HOME EDITION
Other Components: Altec Lansing Speaker System
500wtt Power Supply
Lian Li Rh10 Removable Hard
Drive Unit.
Hewlett Packard 940c
Saitek ST200 Controller
Notes: Mobo Raid Capable.
I have the Maxtor MAXTOR D740X-6L 60GB 7200RPM 2MB 8.5MS ATA133 INT IDE And its great no complaints at all.
They have the d70 proformance drives in 80gbs as well!
