Originally posted by: GuybrushThreepwood
first off, working out does not work unless you eat right.
That's just not true. If this guy is only 10 lbs overweight, and has maintained this with no activity, a simple excercise plan will drop those pounds, and no diet change is needed.
In fact, exercise is far more effective than diet change if the person has been inactive. From what he has said it's obvious he suffers not from a bad diet, but from inactivity.
Evan, run or bike hard every morning. If you can't, do it AT LEAST every other morning. Work your way up to 45 minute to one hour runs or bike rides and you'll lose that weight in no time. Running only a mile and a half wont cut it. Work your way up to at LEAST two. Four would be better.
The point is, you must do it religiously. You have to be obsessive over it and feel as if something is wrong if you've missed your morning run or bike ride.
Don't bother with weights. Only regular 30 minute + cardio programs will take the weight off, and get rid of any spare tire you may have around your waist. Once you've lost the spare tire, then you can worry about building up some mass if you feel you want to.
