OK I'm about to the end of my rope. I have a KA266-R. I currently have 3 hard drives in it on the onboard RAID Controller. On channel 0 I have 2 drives and on channel 1 I have a single drive. On my IDE channels I have a zip drive on one and a CDR on the other. Both of the IDE channel drives are set to Cable Select (currently) They are detected as Master of their respective channels at post. I have set up the three hard drives as striped in the RAID bios. The slave from channel 0 and the master from channel 1 are striped and the master from channel 0 is striped by itself. The array with 2 drives is selected as bootable, size was set to 32, and write cache was enabled.
I then was having trouble seeing the drives when trying to boot with a win98 boot disk so I went into the Iwill bios and disabled the IDE channels. It then booted and let me FDISK the drives for partitioning and setting the active partition, which I did.
After that I rebooted and turned the IDE channels back on in the bios. I then proceeded to boot off of a Windows 2000 Adv Server boot disks. I hit F6 to load my RAID driver went through all the motions and got to the the final disk where it said it was starting Windows 2000 setup and it just flat out hung. I let it sit for 30min and nothing.
I had just finished installing win98 on another computer (this one was the SDRAM version of the same Iwill board) It too is set up in RAID but with only on drive per RAID channel and one dvd drive on the regular IDE channel. I booted off the disks like I was going to do a setup and had no problems like above.
I have tried multiple settings for the above computer. I set all the drives to cable select, I've assigned which are master and slave, I've even tried this with a single drive on each RAID channel and still come up with the same problem. The only thing I can see that is different is the fact that all the drives in the new setup are different sizes, which shouldn't matter but....
Can anyone help me, I'm running out of ideas and tired of loosing sleep the past 2 nights. E-mail me at jpn1833@yahoo.com if you can. I can get to that address from work in a few hours. Must sleep now....
Jon
Jon
