Need Quiet and Effective HSF
treydawg
47
My current combo of a Volcano 7 and XP 2000 is just too loud for my dorm room at night. Can you guys give me a quiet alternative? TIA Trey
Lord Evermore
9,558
AX-7 or the newer thermalright heatsinks, with a low-speed fan like a Panaflo L1A, or an adjustable speed fan. There's another thread similar to this still current.
viper118
104
If you are running a stock system without any overclocking and you aren't planning on doing any overclocking, then I would probably suggest grabbing a Zalman HSF and Fan. It has a really nice flower design and does quite well with cooling a stock system.
It is very quiet and made of copper. The 92mm fan can run in silent mode which is only about 22-24DB... This is pretty much silent and shouldn't cause you any problems related to noise.
Maki
273
Get one of the artic cooling hsf units. Very quiet. Don't plan on over clocking.
PraetorianGuards
1,290
I agree with Viper. I have the Zalman(with an XP 2000+) and while it keeps the processor a little hot, it's not that bad. The Zalman is pretty darn quiet and resonably priced(~30 from Casecooler). I have it running w/no case fans and just the psu fans and everything is fine. Like I said, the temps are a bit high but within limits. I leave the comp running SETI 24/7 and it's stable(as stable as a comp can get w/a Microsoft OS hehe :p)
