need quick case advice
Which one do you prefer, or can you not decide? What are you into, and how much stuff do you plan on stuffing in these cases? (And if you put links, it makes it less of an effort trying to search for evrything, btw. Just a thought). Hold on while I go look at these things.
Tas.
Lian Li. More slots available... Although the Antec case might be quieter with a single 120mm fan, if that is going to do enough cooling for you. So...
Space = Lian Li
Noise = Antec.
Which one is more important to you? I myself would go with the Lian Li...
Tas.
