I have an AMD Barton-M 2500+
768MB RAM
9800np @ Pro+ speeds
2x80GB HDD's
300w PSU
Audigy
Abit NF7 v2.0
Keyboard/mouse etc
5x 80mm fans (including CPU fan)
My PSU is not cutting it, I have instabilities if I run my RAM at its rated speed (I have one PC2700 and one PC3200 stick, they won't run at PC2700 speeds with 2.5-3-3-11 timings
256MB TwinMOS PC2700 CAS2
512MB OCZ PC3200 CAS2.5)
Upping the voltage doesn't really help.
My 9800 can also get flaky if I push it too hard (ie: comp crashes and reboots, not a card issue, power issue).
My 2500+ could run at 133x17 (2266MHz) with my old PC2100 RAM, at 1.6vcore, but will run at 15x145 now (~2200MHz) at the same vcore. Does increasing FSB affect power draw more than pure clock speed?
My 12v line is 11.7
My 3.3v line is 3.2v
Can't check 5v line without a different program to monitor, but I'd guess it won't matter since the other 2 lines aren't too good, so safe to say it's not too great either.
Should I get a new PSU with high 12v lines, or with high 3.3v and 5v lines?
Antec seems to have slightly higher 12v, 5v and 3.3v lines than my current PSU, but an Enermax would have much higher 12v, but similar 3.3v and 5v lines, so which is my best bet?
Is it likely to be a lack of power, or flaky voltages that are causing the problem?
768MB RAM
2x80GB HDD's
300w PSU
Audigy
Abit NF7 v2.0
Keyboard/mouse etc
My 12v line is 11.7
