- Jul 22, 2000
- 4,694
- 0
- 0
For those here who actually do serious weightlifting, I have a few questions. I myself have been doing it for a little over a year (well, 4 months total, with weekend workouts during the school year) and went from being 5'9" super skinny (115lbs) to 140lbs in 3 months. That was my first attempt and I did so many things wrong it's not even funny. And I bet I still do a lot of stuff wrong; not nearly as much as the other people I see though. Then school started and with sports I didn't have time to lift so I stayed at that weight. Now I'm back to training, already up to 150lbs in about a month's time (still the same height). Trying to go for 165-170 by the end of August-mid September. Is it possible? Anyway, I now follow a 3-day routine:
Day 1: chest/back
Day 2: legs/stomach
Day 3: arms/shoulders
I do mostly free weights, with a few machines here and there (for instance, leg press because free weight squatting hurts my shoulders/upper back). So, my questions:
What do you do to build your calves? I can do toe raises with as much weight in each hand as I can hold for a minute (usually 75lbs) without a problem, yet my calves aren't big at all. We also have this machine but I doubt it does anything. Is there a way to do it on the leg press or something?
What do you do for triceps? I used to do dips w/extra weight, but the last 2-3 reps I usually strain and end up hurting my neck or something, so I stopped doing that. Cables don't seem very efficient either. Now I do that overhead arc lift and the isolateral press (kind of a machine, works mostly triceps and some deltoids, like a vertical bench press).
What do you do for your lats? I pull 75lbs each side 10 reps no problem, but it doesn't hurt like it used to. The reason I don't go up in weight is because even with straps I can't hold any more in either hand.
I know strength training is usually 4-8 reps, but do exercises like those for calves need more? Because I know for a fact I can't hold the amount of weight I would need to only be able to do 8 reps, and my legs are still small.
Perhaps I'm just complaining and trying to rush things, but after a session with a guy 3x my size about bench pressing I found out some important things I was doing wrong. Not that I want to be that large (and genetically, I don't think I could even if I wanted to).
Oh, and as far as supplements go, this is all natural, unless you consider a kid vitamin every morning and 1-2 Powerbars/day to be supplements. I just eat a LOT of meat. I need suggestions!
			Day 1: chest/back
Day 2: legs/stomach
