Need pro help with PCI Bus Mastering
brett72
4
Does anyone know how to enable PCI bus mastering on a Voodoo 4 PCI? I have looked in BIOS setup and there are no options for the PCI slots in there, although the computer is an Aptiva and I think they keep the setup options in the BIOS fairly limited. I have installed the card in each PCI slot to see if it would work but that didn't change anything. I have tried Tweakbios and numerous other programs but all with no luck. I think I may be getting decreased performance from the card (as reflected in my truly pathetic 3DMark 2000 scores) because of this, so any suggestions, advice or information will be GREATLY appreciated.
Cheers.
specs: Aptiva 2199/100 amd k6-2 450mhz 192mb RAM Voodoo 4 PCI
