Need Power Supply & Heatsink suggestions!
Bagheera
310
Hey guys! :)
I recently purchased a new system to replace my old, smoking Celeron 400. I would have purchased the parts myself but my dad insisted that I buy it from a local store (something about business contract or whatever. None of my business). So what happened was that I specified as many major components as I could. ut as for small things like heatsinks and power supplies, I just didn't know enough about the models out there to specify. So the store ordered them, of course. I went to the AMD homepage afterward and noticed that both my power supply and heatsink for my Thunderbird 1.4 GHZ are not AMD certified. I am not sure if they will cause a problem or not.
My power supply is a Snake-Snake 350 W ATX (no one's probably heard of the company before. Quite popular in Taiwan but NOT AMD certified. In fact one interesting fact I noticed is that SevenTeam does not have a 350 W model; only 300W and 400W. Is there a specific reason for that?)
My heatsink is made of pure copper (not just the base, the entire thing), and the CPU fan, according to the system monitor, is spinning at 5600 rpm. The manufacturer (I am translating this directly from Chinese) of the fan is PolarWind. I don't know if the sme company manufactured the heatsink or not, though it's more likely the case. I also have no idea about its air flow capacity or heat resistance rate, etc. Again this heatsink model is widely seen in Taiwan but it's not AMD certified, either.
So... I kind of need you guys' thoughts on that. And if you think those two parts are inappropriate, may you suggest some brand and models (please include an estimated price if possible!) for me? :)
sohcrates
7,949
well, IMHO , any decent 350 watt PSU should be allright for an athlon. trust me, i've seen some VERY shady power supplies work just fine with fast tbird systems
as far as the heatsink, as long as you're not overclocking, it should be allright. but just keep an eye on the temperature. if, at full load, you're running anywhere around 60C or higher in the CPU, you might want to think about upgrading your HSF
anand just did a socket A cooler roundup where you can read-up on the best HSF's for tbirds. just go to the main anandtech page and the link is right there
btw...if you DO decide you want a new PSU, i usually suggest SPARKLE power supplies. they've been around for a long time, and i use them on all my systems. i believe enermax makes some pretty good ones too
Bagheera
310
Yeah I checked that article out. :)
But I heard the 1.4g tbird is very hot! And my heatsink look rather similar to the Cool Jag, but the fan is only 5600 rpm though. Could that be the problem? Or may be too much thermal paste was applied?
I didn't put the heatsink on, a local store did. Should I check the thermal contact?
sohcrates
7,949
i'm pretty sure that chart references a 1.3 tbird
how hot are you running? numbers are important to determine if you're HSF is adequate
Bagheera
310
Ok I finally managed to verify that my heatsink is actually a Cool Jag JAC-212C. However, the CPU fan that's attached to it is not the Delta fan Anandtech tested it with; it is a brushless CPU fan manufactured by some Taiwanese company that none of you probably heard of.
As for the temperature, my tbird 1.4g is running at 60C. That feels... a bit too hot. Considering that on Anandtech's review the Cool Jag actually ranked the 4th place (even though they wasn't simulating a 1.4 Athlon), I am starting to wonder if it's just because of my fan.
However the CPU fan is already VERY loud at 5600rpm. I can't imagine the amount of noise if I buy a Delta fan. >_<
Anyone know a fan that has high air flow while stays rather quiet? Preferably brushless, thanks. :)
Bagheera
310
Yeah I've seem those heatsinks on sale myself in Taiwan. ^_^ But I'll check the review. Thanks!
