Need Photoshop help
Geekbabe
Moderator Emeritus<br>Elite Member
Oct 16, 1999
32,229
2,539
www.theshoppinqueen.com
I need to know how to best change hair color in photoshop. I'm thinking of going red for the summer and want to try a few different shades to get a good match for my skintone before
actually doing it. Any help would be appreciated :)
Czar
create a new layer
paint some of the area you want and then fiddle around in the layer... stuff.. multiply, lighten, darken and all that stuff in the layer panel
Adul
44
danny.tangtam.com
use the pen tool to trace around your hair. then just to a little feathering and copy that section out. if you want me to do it send me the psd file and I will send you it back for your editing.
Soulflare
1,801
A quick and easy way would be to just cut off your hair (on the image), paste it on another layer and
then play around with the "Hue/Saturation" sliders under "Image/Adjust/Hue-Saturation".
Adul
44
danny.tangtam.com
<< A quick and easy way would be to just cut off your hair (on the image), paste it on another layer and
that is what i usually do :)
spyordie007
6,229
usually with something like this I would do a combination of the replace color feature, and hue/saturation.
If you have the picture somewhere public I'll play with it and show you some differant effects you can come up with.
LordMaul
15,168
Select it with either the lasso tool or the magic wand, and go to (I think) Image>Adjust>Hue/Saturation, check the box that says, "Color", increase the saturation and pick whatever hue you want. :)
LordMaul
15,168
<< I smell a photochoping thread :D
Runs of to SWF to start one.
Star it here and I may join in. :p
Geekbabe
Oct 16, 1999
32,229
2,539
LOL, be nice Maul, this is important to me, gotta get just the right shade !
spyordie007
6,229
<< but you cant embed images here ;) >>
yes but she can make it available.
dont worry, we are nice, I promise :D
