Need Pentium/Celeron Socket 775 Advice
cyberia
2,535
I am building a kind of media center PC. It will be used primarily to watch an online streaming TV channel. I am not planning on adding a TV tuner and doing TV recording, but I might try to capture the streaming video signal.
Can I stick to a Celeron, or will it be too underpowered even for watching/recording an online video stream? If I do decide to add a TV tuner, will a Celeron handle it.
Thanks.
996GT2
5,212
Depends on what speed the Celeron is, but considering that Pentium 4s/ Pentium Ds are so cheap you might want to check those.
cyberia
2,535
I don't think that motherboard supports Pentium Ds. As fas as pricing on P4s and Celerons at Newegg:
Celeron D 326 2.66 = $47 shipped
Celeron D 346 3.06 = $59 shipped
Pentium 4 524 3.06 = $86 shipped
For two media center boxes that I am trying to build for my parents and my in-laws as cheap as possible, the $39 or $27 price difference between the P4 and the celerons is kind of significant. Especially considering the single-task nature of the application.
Another way to look at it is, I can almost get two Celerons for the price of the P4.
So, do you think they will get a smooth performance out of a Celeron?
JWade
197
www.heatware.com
well my brother has a dell 2400 with a fx5200 PCI video card in it and a tv-tuner card. has the celeron 2.4ghz 400mhz socket 478 processor in it and he doesnt have any issues doing video on it. i would think the 2.66 or 3.06 celeron would work for you since his 2.4ghz celeron works for him.
may want look at the 515 (2.93ghz) for $77 shipped though as another alternative to teh celeron.
dexvx
3,899
You might want to consider posting on the Dell forums asking what CPU's you can put in it.
The best would be a C-1 Revision 9xx series. Next best would be 6x1 Cedar Mill or Cedar Mill based Celeron (512KB L2 cache)
