Originally posted by: MercenaryForHire
Radeon X300SE. Cheap ($50-60) and worse than a gF3.
Now that I've answered that - what the god damned hell are you doing buying an nForce4 presumably S939 board, and bitching out on the graphics for?
- M4H
Originally posted by: mdahc
If you don't mind having a PCI GPU, then Newegg and other etailers still have some older generation cards for around $40. I thought you strictly wanted a PCIe card.
Originally posted by: Wolfshanze
It really boils down to how much gaming you are going to want to do between now and your new high-end card and how much you are willing to spend.
I suppose it also matters as to WHICH games you intend on playing between now and then. If you're going to play Solitare and Quake 2, something like a PCI GeForce4 MX440 will do just fine... but if you want to play a lot of HL2 and Doom3, I would consider AT LEAST a GeForce 6200 so you can play those games (with a lot of stuff turned down of course).
If you're willing to buy now, sell later, then it depends on your budget, and once again... how much you are willing to spend.
Then for you, I would recomend one of the two choices I listed depending on your budget. A PCI GeForce4 440MX for $50 bucks or a PCI-E GeForce 6200(TC) for $70. Once again, it depends on how much you're willing to part with, the better value is the GeForce 6200... but either should do fine for what you describe.
Quite right... they do... AT $89 BUCKS!Last time I looked, Newegg had a 5700LE PCI card also.
