Need PC Speaker Advice.
Im looking for a set of 5.1 speakers for my PC.
It must have an easy access Headphone jack for late night gaming.
If there is a comparison chart of all the logitech/klipsh speaker setups and overall rating that would be the ideal thing to help me make a decision. I did not find one in google.
The easy solution is to name the most expensive set but I would like to spend around $100.00 for the set. I dont care if its refurbished either.
Thanks Ahead of time.
Originally posted by: Tu13erhead
Good luck finding a Klipsch 5.1 set for $100.
What would you recommend from Klipsh? Maybe I will increase my budget as I see it the speaker sets should last me several PC upgrades in the next couple years so I will increase my budget if I see it as a buy it once and dont worry about it for years.
Originally posted by: LungExpansion
Originally posted by: Ichigo
Start talking $300 then?
The top end Logitechs are $225.00 I dont think I would need anything better. What would $300.00 be?
The Klipsch set you wanted to know about
For $100 you can get Logitech z-5300s.
I have the logitech z-5300 hooked up as home theater surround sound and they are great (and unbelivably cheap). The headphone jack works very well giving good sound. However, my cheaper altec lansing 5.1 system's headphone jack makes the sound very "tinny." My recommendation would be the z-5300's
Yep, for that price range Z-5300s. The Klipsch's 5.1 system is at $300, and that does do wonders, but it's probably more than you need.
Norm
Thanks all the logitech z-5300 look like the way to go. Does anyone know if they have optical input or coax? I will google a review as well but figured I would ask anyway since a few of you seem to have these.
Thanks again.
Thanks again.
No, just analog but that's all you really need for hooking up to a PC.
