need painting tips for gundam model...
Omegachi
3,922
i recently got a kemper gundam, and i want to paint the pieces to give it a more realistic look. now i am a noobie at model painting, i have no clue what type of tools or paints i should use. so my question to the experienced model painters is, what type of paint should i use, and what are some things that i should look out for.
*update*
oh god...this is a lot of work
i am trying to cut the pieces out of the tree and try to do it as perfectly as possible...
*update2*
Shi7! i fcked up on the spray paint job... the paint is bubbling up on the pieces.arggggggg
zephyrprime
7,512
Enamel paint is the best but it is harder to work with. Most people start out with acrylic.
Here are some random tips:
Here what I do: Get some epoxy putty from home depot. Then get some little wooden sticks while you are there. Cut up the little wooden sticks and then use the putty epoxy to attach to the model pieces. This way, you have made a little handle for the pieces! This is really useful. You can cut off the handles when you are done with them.
Airbrushes yield the best results but you wouldn't want to get that sort of stuff until you are serious.
A heat lamp is useful for accelerating drying. Fans can also do this but if you use a fan, you gotta be careful of blowing dust onto the model. Use a hepa filter to prevent that from happening.
There are a lot of books on this topic but most of them are written in Japanese unfortunately.
Get to know your local art store. Maybe the staff there can help you out?
Maximus96
5,388
when i was into it, i spent weeks to glue the pieces together, then wetsanding the seam till smooth. then spray painted with primer, then spray paint. paint brushes suck because it leaves brush marks.
TallBill
46,017
62
Used to paint warhammer 40k pieces myself. Never played, but painting was amazingly fun. Dont have many tips to offer though, except to be patient.
TallBill
46,017
62
Yeah, but you can use brushs to build texture. Unless you're doing a model car, you can use it to your advantage.
Spydermag68
2,616
99
For the most part I use Model Master paint. It is an oil based paint that you need to use paint thinner it get it off the brush. I also use a mix of paint and paint thinner in a seprate jar to paint with. It produces a smother finish.
Also I use several brushes base on the area size and detail I want and need.
After I base code the model and let it dry I then "dry" brush the model. Dry brushing is used to give several different highlights to areas of the model. For this I will mix a lighter or darker shade of the base color to get the effect I want. Before I apply the highlight to the model I dry most of the paint off of the brush on a paper towel. Depending on the area I use different size brushes.
I will also use Winsor and Newton inks, water based. Just one or two drops in about 6 drops of water works well.
Spydermag68
2,616
99
You can reduce or eliminate brush marks by using a mix of paint and paint thinner.
Starbuck1975
14,698
1,909
Depends on how extensively you want to paint the model.
The first thing you will need is primer. Krylon makes some excellent matte primers that apply evenly and dry smooth. The last thing you want is a primer that gives the model a gritty texture.
As for paints, I typically paint a wide variety of fantasy and sci-fi models, so I have sampled most of the paints out there. I am not a huge fan of paints made by companies like Testors, Tamiya or Model Masters. The coverage and workability of those paints is somewhat limited, although for your purposes they may work. I would recommend acrylic paints, as you can thin them with water and it makes cleanup a whole lot easier.
My favorite paint line is Reaper Master Series. The paints come in triads of shadow color, base coat and highlight color.
If you want a realistic battle damaged effect on your model, you will need to use a technique called washes. After you lay down your base colors, take darker shades of the base colors, or another color (red brown for rust, blackish-grey for smoke, etc.) and water it down until it is almost transparent. Then simply brush on this thinned down color in a series of washes. Only a little of the color will remain, giving the effect of weathering or battle damage.
You can also choose to drybrush over the washes once they dry to further the effect. With drybrushing, you load your brush with paint, and then wipe most of it off with a cloth. With the remaining paint on your brush, make very quick brushstrokes over the model in random directions. The edges of the model will pick up the paint, giving a light source highlight effect.
Now comes the question of painting the grooves between the armored plates on your Gundam model. Some people use artist quality ink pens, which you can find in a variety of thicknesses and colors at any art store. I tend to use a very thin brush and line these grooved areas with paint. This process is called lining, appropriately enough, and it requires that you water down your paint color to the consistency of milk. This will ensure that the paint flows into all the crevices of your model without tampering the coloring on the surrounding areas. Some people use black, which is probably appropriate for a Gundam model. For a more realistic effect, variations on shades of brown or grey work as well.
Finally you need a sealer to protect your paint job. Again you can find a variety of finishing products at any art store, in either a matte or glossy finish depending on your preference. Some modelers swear by Future floor polish for sealing their models, and you can find recipes online on a number of modelers websites.
Omegachi
3,922
thank you all for your replies, they are all very helpful.
wondering if you guys have pictures of your models up online for me to see and use as an example...
Mermaidman
7,987
93
LOL, what kind of industrial-strength paint did you use? Sorry I didn't mention this in my earlier post, but I think you should brush paint your first few models. As for WHEN to paint, you have to use your judgement. Some parts should be left on the tree and painted, some removed and painted, and some should be painted after assembly. Practice and experience.
