As I mentioned in my last thread http://forums.anandtech.com/showthread.php?t=2048431 my 9800GT died a couple of weeks ago. I managed to get by without a decent gaming machine because I had just finished ME2 and I had no real game I felt I absolutely needed to play right now.
I have been using my HP DV2 ULV laptop for the last couple of weeks and it's been better than I expected really. It's just a Athlon NEO MV-40(1.6Ghz Athlon 64 with a much lower voltage basically) and HD3200 mobile graphics. Needless to say I can't watch HD youtube videos or play any real games on this thing(it's mostly a web on the go and powerpoint viewing during class machine). And the upgrade bug has started to hit me.
I haven't really upgraded or built a computer since like 2005 where I lost interest in the hobby. Needless to say PC gaming has changed a lot since the last generation of consoles were launched. So I have been shopping around and looking at the different options that I have and it somehow revived the interest I had lost in the PC hardware arena. About 8 or 9 years ago I would have been the one roaming the forums and helping out people but this time I need you guys to help me decide what I should do.
Pretty much what I decided on doing is that i'm going to upgrade to a 5xxx series card. My budget is going to be about 200$ CDN at the top range but closer to 150 would be ideal. Also I want whatever I buy to be strategic in terms of having good upgrade options in the future as I plan on trying to keep my machine more up to date than what I have been doing int he last 5 or 6 years this time. I think I should mention that my monitor runs at 1680*1050 but that I might consider getting an extra monitor(or two llol) in the future.
So the first dilemma that I have is between getting something cheaper and similar in performance to what I had before, saving the extra dough for a better purchase in the future or just buy something significantly better right now. What I have in mind by this is something like a 5670 would be under 100$. Now obviously this won't really be better than my old 9800GT but I guess the feature set would be better and I could potentially get something far superior in about a year when current gen card prices come down and refresh parts are launched.
My other options are getting a 5750 or 5770. This is the options I am leaning towards right now. My thoughts on this is that I can get a card now and in the future when I upgrade my motherboard/cpu I can get a crossfire motherboard and and extra card on the cheap to make for an easy upgrade path. Also i'm not sure if the extra price difference between the 5750 and 5770 is really worth it.
Another thought that I am having has to do with overclocking and noise. I don't think I would need to overclock a card I get right now to have acceptable performance but it's nice to have the headroom to squeeze and extra 10-15% out of your hardware when you need to in the future. This is why i'm not sure if it's worth it to get a card with the "old" stock cooler or if the $$ difference makes getting something a bit better like Vapor-x worth it.
Finally (and I guess this works with the above paragraph as well) I wonder about different brands. I guess i'm asking about the differences between the brand cards and if's brand X is worth spending a bit more than brand Y. Since I haven't bought a new video card from a vendor in over 5 years I need you guys with experience with the different manufacturers. For example should I just go with the cheapest card possible and maybe get a 5770 or is it worth it buying something like a Sapphire Vapor-x cooled 5750 card for a bit cheaper. Another thing I might like is the XFX lifetime warranty. It might be worth it.
As I mentioned previously I am in Canada so my buying options are more limited but it's still not bad. From what I see newegg.ca is cheaper than my other options but if you guys have other suggestions i'm always open to buying from somewhere else.
More specifically these are the cards I was looking at the most
http://www.newegg.ca/Product/Product...82E16814102865
http://www.newegg.ca/Product/Product...82E16814150448
http://www.newegg.ca/Product/Product...82E16814150447
http://www.newegg.ca/Product/Product...82E16814102868
Also if you guys have other suggestions like good deals on 4xxx series cards or Nvidia cards i'm open to them.
Thanks to anyone who read the whole thing and I have I did not leave out and important details.
