- Jul 30, 2000
- 1,829
- 0
- 0
I have $225 in flooz that I want to use on a monitor, so I'm stuck with outpost.com. and this seems to be the best deal in my price range. Of course, I'd prefer a 19" 1600 x 1200... but don't want to shell out the extra $. Anyone have experience with this? Should I wait and keep shopping around? Right now, I'm at 800 x 600 on a .28, 14" (don't laugh!!), so this is a few steps up. I don't think I'll need anything extra to run this (like a video card, right??).
Thanks
$239 after rebate:
Description (Manufacturer# 753DF)
The SyncMaster 753DF DynaFlat? monitor features the flattest tube available. It is perfectly flat with no visible curvature from any angle. Combine that with superior color saturation and sharp, crystal-clear images, you'll find a performance level that's hard to match.
Specifications:
Type Device: Color Monitor
Actual Diagonal Screen Size: 17in
Viewable Diagonal Screen/Image Size: 16in
Video Standards: SXGA, VGA, SVGA, XGA
Dot/Stripe Pitch: Horizontal, .20mm
Screen Type: Anti-Static, Flat-Screen, Anti-Glare, Invar Shadow Mask, 90-Degree Deflection
Maximum Resolution Supported: 1280 x 1024
Displays a maximum resolution of 1280 x 1024 @ 66Hz
Is this refresh rate good??
Scanning-Horizontal Freq: 30-70 KHz
Scanning-Vertical Freq/Refresh: 50-160 Hz
Bandwidth: 110 MHz
Interface Type: DB15 (VGA)
Controls:
Focus, Digital Front, OSD Controls, Brightness, H/V Position, MoirU Erase, Contrast, H/V Size, Pincushion Distortion/Balance, Parallelogram, Trapezoid, Pin Balance, Manual Degaussing, Vertical Linearity, Language Select, Barrel, Rotation, Zoom
Cabinet Color: Gray
Display Memory Settings: 8 Preset, 8 User
Certifications:
UL Listed, FCC Class B, MPR II (Sweden EMI), PTB (Japan), CSA (Canada), SETI, IEC950 (Safety), NOM, DHHS Rules 21 CFR, CCIB, TUV (Germany), DOC-B, TCO99, EIAJ, DEMKO (Denmark), NEMKO (Norway), SEMKO (Sweden)
Input Voltage: Universal 120/220 VAC, 50/60 Hz
Software Included: Colorific
Misc Features: Tilt and Swivel Base, PC Compatible, Macintosh Requires Adapter
Thanks
$239 after rebate:
Specifications:
Bandwidth: 110 MHz
Controls:
Cabinet Color: Gray
Certifications:
