need opinion/review/other options on chosen laptop
daddyodevil
I have decided to buy a Lenovo G50-45 with AMD a8 6410, 4gb ddr3 1600 mhz, 500 gb, win 8.1, i plan on adding another a 8gb ddr3 in the extra slot, as for the laptop( only lappy), the max i can spend is around 400$ , my prime requirement is coding , i am learning to code c, java, c++,etc, maybe a bit of VMs for trying out other OSes. i will carry the lappy to college for watching tutorials. i have heard amd processors tend to heat a little too much so planning on getting a cooler too ( cheap one ),but cant carry that to college, so i would like your views on any amd heating issues i will face and is there any possibility i can add an external pcie express slot( or whatever it is called) to my lappy to connect the graphics card of my desktop to this, also i would like to know how adding that extra 8gb will help, and lastly would you recommend any other laptop in my 400$ price range.
