- Jul 6, 2007
- 6,799
- 1,103
- 126
I have a corporate side LAN running Windows 2003 (AD, DHCP, WINS & DNS)
Server LAN IP 192.168.1.8/24 GW 192.168.1.254 (Netopia DSL Cayman 3500 router)
RRAS disabled and registry IPEnableRouter on
Key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters
Value: IPEnableRouter
OpenVPN server IP 10.8.0.1
Remote client side
LAN IP 10.1.1.6 GW 10.1.1.1
OpenVPN IP 10.8.0.2
Client and server can ping and see each other and view files on thier disks either way,
but Client can't ping any workstations on 192.168.1.0 network or vice versa.
I follow pretty much the instruction at http://www.runpcrun.com/howtoopenvpn
but I really don't have idea how to add a route.
Cayman can let me add a static route, it's like
Destination Network:
Netmask:
Gateway:
Metric:
RIP Advertise : Split Horizon/Always/Never
What should I do? Add a route on router (Netopia) or add a route on the server? And what should it look like?
I'm really bad at routing concept. Thanks!
*EDIT*
server.ovpn contents:
## server.ovpn ##
port 1194
proto udp
dev tun
dev-node MyTAP
topology subnet
ca "C:\\Program Files\\OpenVPN\\easy-rsa\\keys\\ca.crt"
cert "C:\\Program Files\\OpenVPN\\easy-rsa\\keys\\server.crt"
key "C:\\Program Files\\OpenVPN\\easy-rsa\\keys\\server.key"
dh "C:\\Program Files\\OpenVPN\\easy-rsa\\keys\\dh1024.pem"
server 10.8.0.0 255.255.255.0
push "route 192.168.1.0 255.255.255.0"
push "dhcp-option WINS 192.168.1.8"
push "dhcp-option DNS 192.168.1.8"
push "dhcp-option DOMAIN mydomain.local"
keepalive 10 120
comp-lzo
persist-key
persist-tun
status openvpn-status.log
verb 3
Remote client side
OpenVPN IP 10.8.0.2
Netmask:
Gateway:
Metric:
*EDIT*
## server.ovpn ##
port 1194
proto udp
dev tun
dev-node MyTAP
topology subnet
keepalive 10 120
comp-lzo
persist-key
persist-tun
verb 3
