- Jul 15, 2003
- 80,287
- 17,080
- 136
I know I might be wasting my time but I thought I should post here anyway. Everytime I post at Pirate 4x4 I get picked on or ignored.
Have enjoyed my little S-10 in the mountains of Oregon for some time now. Moved back to Virginia and want to go out again but my vehicle needs a little work.
Its already got a 6 inch lift and a slightly-better-than-factory suspension. When I got sick of the rain in Oregon I took it over to a body shop and had the guys put some shit on the undercarriage thats supposed to be the equivalent to Rhino Lining. Just protecting it from water wasnt enough, it also had to stand up to abuse. The rubber stuff would peel right off after a day in the brush.
The front and rear bumpers are stock and they have taken a lot of damage from innattentive female drivers and assholes in parking lots.
I want to replace them with something generally considered good for off-road use. No plastic. No fiberglass.
Searched online for a week and I get plenty of results for full size pickups. The problem is I can't seem to find many parts for small pickups. Certainly not any performance parts designed to stand up to rocks on the trail. Are small pickups really so despised in the off-road community? Most of the praise for Jeeps comes from their small size being able to wiggle into tight areas a large pickup wouldnt fit.
Wondering if anybody knew of a place to get such things. I dont wanna spend more than a thousand dollars for each bumper but I am flexible.
Should I just keep the damaged factory bumper and slap a brush guard on the front of it? If so where can I get one for an S-10?
