I have the gainward golden sample and their expertool. however, the expertool seems to limit clock speeds. is there another tool that works better for this?
CoolBits works great but RivaTuner is way better. Not only can you overclock with it, you can tamper with settings to improve quality if your system sucks it hard. You can change which version of pixel shader and which version of vertex shader to use. It's really nifty 🙂.
