- Aug 17, 2000
- 21,204
- 66
- 91
Well, let me say that I'm new to Pentiums and this Mobo has a lot of bios settings that are new to me also. I'm trying to follow pastorjay's blueprint using a 2.4b(C1) for an OC that he tells about in this thread. I'm a bit lost as to a lot of the bios settings for a OC. I thought I'd try here before I PMed pastorjay.
Ext. Clock:
I assume by choosing User Define that I will then be able to set the fsb.
PCI Bus Frequency:
My guess is that out of Ext. Clock/3, Ext. Clock/4, 44MHz(fixed), 37MHz(fixed), and 33 MHz(fixed) that I would pick 33 MHz(fixed) unless I would want to OC PCI devices.
Multiplier Factor:
This is locked with Pentiums, isn't it? It'll be 18 on a 2.4b, right?
DRAM Ratio H/W Strap:
Options are Low(for CPUs with 400MHz FSB), High(533MHz), and By CPU. Hmmmmm, here I am lost.
DRAM Ratio (CPU: DRAM):
Options under Low(DRAM Ratio H/W Strap) are 1:1 or 3:4 under High(DRAM Ratio H/W Strap) are 4:5 or 1:1 or you can choose By SPD. This is another setting that I'm totally lost on.
Any help will surely be appreciated.
Ext. Clock:
PCI Bus Frequency:
Multiplier Factor:
